satoh s650g loader not working but 3 point does
   / satoh s650g loader not working but 3 point does #1
nys650g
Dansville NY
Satoh S650G
Loader not working but 3 point does but its surging was low on fluid so I drained it and am cleaning screen now. could low fluid cause this? Or possible other problems? Just bought this got it running after sitting 3 years
   / satoh s650g loader not working but 3 point does #2
Welcome!
I've got an S550G which uses the same Mazda PB100 engine as your tractor, and the front loader on this one has its own pump for hydraulics. Pretty sure yours does too, but I have been wrong before!
This one has a pump mounted on the right side of the engine in front of the governor. The hydraulic fluid is located in the right side upright of the loader, near the hand controls.
If this is the same make sure that has fluid and a good belt.
If I am totally wrong and yours runs off the trans/3 point, check under the radiator on the lower front of the engine. There is a shaft that runs the pump for the 3 point hitch. Make sure it is operational. I had that come loose with some heavy use and the hitch got real sluggish; tightened the bolts down and all has been good since!
Good luck and here's a link you might find useful: The Satoh S650G Bison Tractor Information Resource
~gm66
   / satoh s650g loader not working but 3 point does #3
The hydraulic pump is located just below the radiator and supplies all the hydraulic needs. It is located below the radiator and powered by the crankshaft. The connection block may be loose or (very likely) stripped out. It is designed to do that when placed under too much of a load to keep from breaking the hydraulic pump shaft. There are replacements available and I wouldn't try making your own as the metal is soft so that it will protect the pump properly --the voice of experience :( -- I had a machinist modify my pump to use a lovejoy connector and that has worked well for me. This page explains it:
http://www.tractorbynet.com/forums/mitsubishi-satoh/162830-s650g-hydraulic-pump-problems.html
All the best to ya.
Got it all straightened out low fluid and filter dirty . Any sources for a new filter screen is pretty shot. Thanks for the input
   / satoh s650g loader not working but 3 point does #5
The screen is normally a simple bronze mesh that an EBay search will locate.
All mesh sizes can be found by the sq foot at low $$.
Opt for brass as you can solder easily to fit.
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2 Vintage Metal Signs (A48082)
2 Vintage Metal...
2008 Honda Civic Sedan (A48082)
2008 Honda Civic...
Landoll (A50657)
Landoll (A50657)
2006 FAE Mulcher (A49461)
2006 FAE Mulcher...
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
