Satoh S650g Hydraulic problems
   / Satoh S650g Hydraulic problems #1
nys650g
Dansville NY
Satoh S650G
I was using this tractor 3pt and loader worked fine parked it then nothing worked. I checked the obvious, fluid, leaks etc all was fine. So i check the block at the pump and sure enough it was stripped. Switched it out for lovejoy connectors and still nothing. New fluid and filter done . Any clues im lost? I was able to torn pump by hand, so is pump bad?
   / Satoh S650g Hydraulic problems #2
You probably need to determine pressure and flow out of the pump. The fact that it turns by hand doesn't necessarily mean it is working.
2002 FREIGHTLINER FL80 FUEL TRANSPORTATION TRUCK (A52472)
2002 FREIGHTLINER...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
Toro Workman Utility Cart (A51694)
Toro Workman...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2011 GMC SIERRA 2500 (A52472)
2011 GMC SIERRA...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
