3-Point Hitch Satoh S-650B overheated - won't start
   / Satoh S-650B overheated - won't start #1
Ironbird
Satoh 650G
Hi Folks-
Things are looking bleak for my older Satoh S-650G tractor. It's had either a Mazda or Mitsu motor.
Here's a couple numbers that I was able to find on it. S262114 stamped on the block. S-650G-401933
on the tranny.
At any rate, it has been running hot all summer and typically I fill the radiator full of coolant when
I start to mow. After about 20 mins it will blow all of the coolant out of the overflow tube as steam.
I then have to wait for it to cool down re-fill and continue mowing. Well, this last time I must have
waited to long to cool it down because it stalled and won't re-start for anything. It turns but doesn't
sound like it is firing at all. I pulled the plugs and 2 of them were wet with fuel/coolant (not sure which but
smelled like mostly fuel). I cleaned the plugs and re-installed them. I checked to make sure I'm getting spark
at the coil as well. I pulled the rotor cap and cleaned the contacts which didn't look bad at all. I spoke briefly
with my local tractor mech and he said it would be bad thermostat or water pump that I may have warped the
head. Any suggestions that I can pass along to my mechanic before I have him pick it up. He is worried about
parts availability and I'm worried that the motor is toast and not worth fixing. Thanks in advance.
-=Ironbird=-
UNUSED AGT YSRT14 STAND ON SKID STEER (A51243)
UNUSED AGT YSRT14...
2002 CASE INTERNATIONAL MX270 TRACTOR (A51243)
2002 CASE...
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
(4) 16' Tarter Pipe Gates (A50515)
(4) 16' Tarter...
2016 Chrysler 200 Sedan (A50324)
2016 Chrysler 200...
2011 Cadillac SRX Luxury SUV (A50324)
2011 Cadillac SRX...
