Satoh S-500 Any Info???
   / Satoh S-500 Any Info??? #1
AVSatoh
High Desert, CA
Satoh S-500
I have a Satoh S-500. I don't know what year. It has a DST90 2 Cylinder Diesel engine. I have had it for about 15 years and am working to get it running again. Need info on fluid types and capacities, etc. I have searched the web and have found nothing about this tractor. Any help would be greatly appreciated. Thank you.
   / Satoh S-500 Any Info??? #2
Never heard of that model or engine model.
   / Satoh S-500 Any Info??? #3
You should post some pictures .
I will post photos soon. Thank you.
I posted two photos of the Satoh S-500 in the photo gallery. I hope this was the correct place. I was unable to get the picture to upload here. This is the first forum I have used.
After much searching and reading, the S-500 appears to me to be very similar to the early S-650g in size, and has a split system of the transmission and hydraulic system like the S-650. The S-500 has a 2 cylinder diesel vs. the gas engine. I don't know if that helps, if anyone can direct me to where else to look for info, that would be great.
Thank you.
For those looking for info on the Satoh S-500, here is what I have found so far, after lots of searching...
It appears to have been made in the late 1960s or prior to 1972, and was part of the same line at the 650G. There was a S350, S500, and S650G. These models had the headlights on the side. 1972 and newer 650G have the headlights in the hood.
The S500 was made for the US Market, and was imported by NEDA. It appears to have been also sold as Dan Brown tractors, at least in the 650G configuration. I have seen a posted cover of the brochure, but no instructions or repair manuals.
The tractor is 18 hp at the PTO, using a 904cc 2 Cylinder Diesel, and has the hydraulic system separate from the transmission. Tires are 8.3X24 on the rear, with 4.00 X15 on the front. The tractor has a 6 speed transmission, 3H and 3L. The engine takes 4 quarts of oil. I used 15-40W Diesel rated oil.
The injectors and injector pump are made by Denso, which is still in business. The air cleaner is the oil bath type. I believe this engine was made by Satoh, based on the Katakana lettering on the DST90 Engine Plaque. The starter is a Delco.
I hope this helps anyone who is looking since it seems to be a very rare tractor.
If anyone has a source for the manuals, please let me know. Thanks.
   / Satoh S-500 Any Info??? #8
I's rather suspect the engine to be Mitsubishi as the took over Sotah.
The Mitsu/Sotah did also have gas engines that were generally Mazda.
2017 Ford F550 Altec Bucket Truck (A52377)
2017 Ford F550...
2007 Ford F-150 Ext Cab Pick-up Truck (A53422)
2007 Ford F-150...
2019 FREIGHTLINER CASCADIA TANDEM SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
2018 Ford Explorer SUV (A53424)
2018 Ford Explorer...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
