Mowing Satoh hydraulic leak?
   / Satoh hydraulic leak? #1
louisianabull
Satoh Bull 4wd
I have a Satoh bull 4wd and it just started leaking a foamy hydraulic oil out from below the starter in the bellhousing area. If I take the plastic plug out and look in the bellhousing I cant see much but the fluid runs out when its running. Looking at the parts book it doesnt look like much is around there except the trans shaft. Not much experience with tractors but fluid in the bellhousing isnt good I know.:confused:
   / Satoh hydraulic leak? #2
Check engine oil level and transmission oil level unless you already know which seal is leaking. Will probably have to split the tractor.
2019 GENERAC MLT6SK-HERC LIGHT PLANT / GENERATOR (A52706)
2019 GENERAC...
Croft 5,000lb Vehicle Tow Dolly (A52377)
Croft 5,000lb...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
