Mowing Satoh hydraulic leak?
   / Satoh hydraulic leak? #1
louisianabull
Satoh Bull 4wd
I have a Satoh bull 4wd and it just started leaking a foamy hydraulic oil out from below the starter in the bellhousing area. If I take the plastic plug out and look in the bellhousing I cant see much but the fluid runs out when its running. Looking at the parts book it doesnt look like much is around there except the trans shaft. Not much experience with tractors but fluid in the bellhousing isnt good I know.:confused:
   / Satoh hydraulic leak? #2
Check engine oil level and transmission oil level unless you already know which seal is leaking. Will probably have to split the tractor.
UNUSED SDLANCH SDLC2030FT ALL STEEL CARPORT (A54757)
UNUSED SDLANCH...
2024 TIMPTE HOPPER 43FT HOPPER TRAILER (A54607)
2024 TIMPTE HOPPER...
2017 Caterpillar D5 K2 LGP (A55218)
2017 Caterpillar...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A54313)
2012 INTERNATIONAL...
