Satoh Bison S 650 G
   / Satoh Bison S 650 G #1
DennisDanger
when I give this tractor gas from an idle or I'm pulling a load it's real doggy and spits from the carb, not a backfire. We put the electronic ignition on it last year, but it still doesn't have the power it used to.Any ideas?
   / Satoh Bison S 650 G #2
I would check to the following : Make sure the governer is working correctly. If it's not working correctly you may not be getting enough or any change in the throttle position when you put a load on the engine. It may be out of adjustment, also. Make sure your timing is at least close to where it needs to be (Did you reset it when you installed the elec ign?). Make sure your vacuum advance it working and there aren't any vacuum leaks. Without being more specific about the spitting from the carb it's tough to figure out what that is.
   / Satoh Bison S 650 G #3
If you have not checked the vacum advance,I would start there.If that is okay then it sounds like a fuel delivery problem.
Thank you, my timing was off and i adjusted the fuel mixture screw. Runs great.
1267 (A50490)
1267 (A50490)
2014 Chevrolet Cruze LTZ Sedan (A50324)
2014 Chevrolet...
Case IH 2608 8 Row Corn Head (A52349)
Case IH 2608 8 Row...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
2019 Chevrolet 2500 4x4 Extended Cab Knapheide Service Truck (A50323)
2019 Chevrolet...
