I have a Satoh Beaver 2wd. The only numbers I can find on it are 11300-701963. That number is stamped into I guess what would be the frame/transmission by the driver's left foot.
I'm having a problem with the PTO. It came with a 48" PTO mower. I ran through a particuarily tough patch of cactus and now the mower won't cut. The PTO and the mower will spin normally until I start cutting, then as soon as I hit some high grass the PTO stops. I haven't heard any grinding or crunching sounds from the transmission. I figured I'd ask what might be going on before I opened it up. Please, someone tell me that there is a shear pin on the PTO. I can't locate any manuals or even an IPB on this tractor. Other than this problem the only other problem I've had is overheating, clogged radiator.
