Satoh Beaver Hydraulic Tap
   / Satoh Beaver Hydraulic Tap #1
WildWest
Texas
I have a FEL I want to add to my Satoh Beaver S370D 4x4
Is there a plate i can buy that bolts on to my hydraulic line for take off?
what are my options i prefer not to cut my hard line im afraid it would be metric or something oddballed
   / Satoh Beaver Hydraulic Tap #2
Try "Valley Power". They were talking about making some Hyd PTO adapter plates or may have one.
The pressure line is metric. Most hydraulic shops should be able to order fittings to loop into the metric pressure line.
I have a Blackhawk loader on my Beaver. I am thinking of adding a PTO pump and reservoir to speed things up. The pump on the tractor is only 3 or 4 gpm @ 2700RPM and can seem very slow when powering the loader. I find it hard to run the machine at high RPM doing loader work so then it is even slower.
Regards,
Mundy
Well the loader i have has an underbelly resivoir/belt driven pump its off some kind of cub cadet lawn tractor or something.
I have to get a few lines and i am going to take it apart and clean everything it has some water in the cylinders.
But i had thought about running the pump instead of having to mess with my tractor hydraulics
Do you have pics of how your loader is tied in?
   / Satoh Beaver Hydraulic Tap #4
Are you talking subframe or Hydraulic?
Here is a link to hydraulic PTO adapter view. Satoh Parts
If your talking subframe I can email you a pic. You will have to supply an email. Your profile will not allow email contact.
Regards,
Mundy
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2002 Freightliner FL112 T/A E-One Pumper Fire Truck (A51692)
2002 Freightliner...
2005 FOREST RIVER WORK AND PLAY (A53843)
2005 FOREST RIVER...
LINDE H80D FORKLIFT (A53843)
LINDE H80D...
TAKEUCHI TB235-2 EXCAVATOR (A52706)
TAKEUCHI TB235-2...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
