Satoh 650G Steering box
/ Satoh 650G Steering box #1
nosbearatu
Minneapolis, MN
Satoh/Mitsubishi 650G
OK so I just took delivery of my Satoh 650G yesterday and after using it an hour to move some snow with the FEL I decided to put the tire chains that came with it on in anticipation of more snow. Anyway, while trying to turn the wheel to better line up the chains I heard a crunch and lost all steering. Once I finally got the tractor in the shop i unbolted the steering shaft at the box and looked down inside, I have stripped 4-5 teeth off the face of the steering gear. :(
So my questions are:
1) How do I repair this?
2) what should I do in the future to prevent this from happening?
Is the FEL heavy enough that I shouldn't be trying to turn the wheel unless moving?
I was really hoping to get more time out of my new to me tractor than a few hours of snow removal.
/ Satoh 650G Steering box #2
Hang in there.
Couple of Mitsu/Sotah guys specialize in spares for your tractor will soon answer.
That, or scroll the Mitsu forum and you'll find their links.
OK so I got the box apart and even though the previous owner replaced the two bearings less than 2 years ago the bearings were severely worn so I guess I will replace those while I am at it. Now the steering gear appears to be different than the diagrams on valley powers website. Those diagram show a worm gear meeting the sector shaft and in mine there is a recirculating ball system (gear block with ball bearings inside), so I am wondering if this is the original box or if it was upgraded with a newer version.
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
2021 PETERBILT PB337DUMP TRUCK (A63276)
2021 PETERBILT...
(2) 4 WAY WRENCHES (A64276)
(2) 4 WAY WRENCHES...
2017 Ford F-150 Ext. Cab Pickup Truck (A64556)
2017 Ford F-150...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
