satoh 650 g-inginiton problems
/ satoh 650 g-inginiton problems #1
gpbibb
I am not getting any voltage from the coil. I am not sure I am getting anything to the coil. Where do I start to trouble shoot? If it is the coil what is the napa substitute for the the original coil?
/ satoh 650 g-inginiton problems #2
To check a coil you need a volt/ohm meter.
Naturally you need to find 12 volts going in at the terminal.
A coil is basically a transformer, 12 volts goes in and HIGH voltage comes out.
A typical resistance reading on the low (in side) will be quite low as there are not many turns of wire .
On the output side the reading will be high as there are many many turns of finer wire.
You read the high from ground (coil can) to distributor wire out, and the 12 vol from the screw terminal to ground.
To be sure of a good ground, scrape or sand a spot on the coil can.
I understand that the 650G is a Mazda engine and as such certain year ford rangers used that engine so auto parts carry replacements.
Good luck!
/ satoh 650 g-inginiton problems #3
use a multi meter or a test light. ground to the battery negative.use probe at battery pos.you get a reading?if yes then probe the coil + side. if no reading probe the starter heavy battery lead.if no reading check battery ground wire.
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
2017 Caterpillar 259D (A64126)
2017 Caterpillar...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
3145 (A63117)
3145 (A63117)
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
