Sander/spreader
/ Sander/spreader #21
Uhhh, how dumb am I? I just bought a used EZ-Flow spreader for liming my fields. This will work with sand and salt as well? Won't the salt corrode the heck out of it?
/ Sander/spreader #22
  • Let me have it and i will get beck to you in about 5 years to let you know how bad the salt corroded it. LOL
/ Sander/spreader #23
I just never thought of using it for anything other than lime...
Now I just need to get the tires and wheels up to snuff on it...
/ Sander/spreader #24
Farmwithjunk said:
I don't have any pictures
All you had to do was ask;)
/ Sander/spreader #25
Keep it cleaned out after use. After you wash it out, spray a coat of light oil on everything inside. No more likely to rust than the metal parts on a typical spinner type spreader. I have an old IH "EZ Flow" spreader that's had tons of corrosive fertilizer ran through it. No rusting problem.
/ Sander/spreader #26
I almost forgot, there is a company that has a small pull type drop sander. I think that it is called an E-Poky. That may not be how it is spelled but that is how it sounds when said. I had contact with someone in Bufflao NY last year, about one. They have one that is made to do side walks. Where I use to work we had one.
/ Sander/spreader #27
What ratio of salt to sand do you use?
I use
3 parts sand to 1 part salt
2 parts sand to 1 part salt
1 part sand to 1 part salt
depending on how strong a salt mix I want with the sand.
/ Sander/spreader #28
How does one activate the feeder gate from the tractor seat?
