I have an 800' shale driveway. About 3times a winter I get iced up real bad.
I need to spread sand. What are some good ideas to store/spread the sand?
__________________________________________________________________________________________________
Hello Chuck172,
It is all going to come down to what you can afford.
A spinner spreader will waste more salt and sand than a pendulum spreader due
to the spinner UNLESS you can purchase one with baffles to direct the sand.
I have no idea what the drop spreaders for sand cost now but they were expensive
when I checked the last time as they are ground driven units.
As you have a 4 wheel drive mule I hope your tires are loaded and you have chains too.
As far as sand goes you have to decide whether you want concrete sand or mason sand.
Any type of sand will freeze unless it is stored indoors with a heat source.
Putting the sand in a bin that is above the ground helps to keep it from freezing as
it is not in contact with the ground.
Another option is dumping it on a round silo tarp and having a second round
silo tarp to cover it and sealing it with a layer of sand to hold the edges in place.
If you have a salamander you can heat the pile up for an hour and then use it
BUT the sand will become a magnet for moisture.
Sticking a dehumidifier under the tarp after the load is dumped will get rid
of all the water in the sand if you buy a truckload of it. Gravel sand is washed to
skim it away from the gravel after while it is screened and after it falls through
the screener.
It all depends on what you can afford or spend.
Buying a pallet of bagged mason sand is another option where you can simply store it indoors
and you have no issues with moisture or freezing clumped sand.
A small three point hitch mounted spinning spreader would work well if you keep the
mule indoors so the spreader stays dry too.
I will tell you that a bag of sand goes a long way when it is spread.
