Sand Barrels & Spreading Sand on Driveways
   / Sand Barrels & Spreading Sand on Driveways #1
OrangeAgain
Albany, Vermont 05820
2015 Kioti RX7320PC, 1983 Kubota L275 4WD, 1981 John Deere 2440 2WD row crop tractor
I am curious what methods folks use to store sand at the their homes / farms and how the sand is spread on snowy and/or icy driveways. Pics will be helpful.
   / Sand Barrels & Spreading Sand on Driveways #2
Sand only, or sand and calcium chloride.
We had a terribly ice driveway most of the winter in WI because of living in a woods and one a small hill with a 700 driveway. Cover with tarp for sure. I got a couple yards of sand and salt mix and dumped it in a good spot. Then it worked best for me to take a shovel and fling it out onto the ice. It only had to be thin because the salt would make it stick and I would have enough traction.
   / Sand Barrels & Spreading Sand on Driveways #3
I have about a yard of salt-sand covered with a tarp. As mentioned above it doesn't take much, throw a shovelful out across your icy drive and it spreads itself well.
   / Sand Barrels & Spreading Sand on Driveways #4
I have a few pails of sand in the warm garage. I spread about 1 pail, by hand, when needed, on a flat 200ft gravel drive. The concrete area between the buildings is always kept clear of ice by scraping clean with plow. I don't use much sand because we have boots that have metal teeth on them for icy conditions.
   / Sand Barrels & Spreading Sand on Driveways #5
The town supplies sand/salt mix. I fill up plastic buckets at the DPW when needed. Built a shelf on my back blade to hold 2 buckets so I can stop and sand the area that need it. Sand Shelf.jpg
   / Sand Barrels & Spreading Sand on Driveways #6
Our town does the same (don't think it has salt in it though...town doesn't even use salt on the roads much if at all). There's a big pile marked "resident sand" at the town garage. I'll keep a couple 5 gal buckets around at a time. We'll also use wood ashes.
   / Sand Barrels & Spreading Sand on Driveways #7
   / Sand Barrels & Spreading Sand on Driveways #8
My driveway is flat gravel. It gets very icy but we don't use any sand or salt. I don't like tracking that scrap in the house.
I use to work for a municipality..i never want to see salt again.
   / Sand Barrels & Spreading Sand on Driveways #9
I usually price pickup load day of need,also spare load to one side just in case.
   / Sand Barrels & Spreading Sand on Driveways #10
I wonder if a fertilizer spreader would work for large areas like a parking lot. Thinking of my church. Several guys have quads which are easier to transport than my BX or maybe a riding lawnmower.
Ron
2014 Dodge Avenger SE Sedan (A51694)
2014 Dodge Avenger...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A53473)
NEW 2024 LOAD...
LINDE WELDER (A53843)
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2005 FORD F350 XLT SUPER DUTY SERVICE TRUCK (A51406)
2005 FORD F350 XLT...
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
