Samurai sickle mower reviews?
   / Samurai sickle mower reviews? #1
frogpond
Snohomish WA
Kubota BX25D
I am thinking of getting a Sabre Samurai sickle mower for the front bucket of my bx25d. I have already installed 3rd function hoses for my Add a Grapple. Do any of you have experience with this implement? Will the bx have enough hydraulic flow? How well does the mower work? I would use it to cut grass, brush, and branches along streams, the pond edge, roadsides, etc. Thanks for your help!
   / Samurai sickle mower reviews? #2
TBN search has 18 entries on first attempt:
How will you control your front remotes? I bought a WR Long solenoid valve and turns out, it's just for intermittent use, like for hyd cylinders, not continuous use like, for that Samurai.
   / Samurai sickle mower reviews? #3
I ran mine on my B26 and controlled the speed with the tractor rpm, it did well and cut down my driveway cleaning time by a lot.
Woody, did you have to somehow bypass your usual 3rd function control? Since I use mine to control the grapple lid, I have it controlled with 2 pushbuttons on the loader joystick. I can see how that wouldn't work to allow a continuous flow.
After emailing back and forth with the maker of Samurai and Dummit Hydraulics, it looks like I will have to add another valve with a D spool, for continuous flow and gradual stop. The present valve with an A spool shuts off abruptly, and will destroy the hydraulic motor, although it is appropriate for operating a cylinder, as in the grapple. Still working out the details of how it all fits together.
   / Samurai sickle mower reviews? #6
Good luck sir
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A52472)
2011 ORTEQ ENERGY...
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A52748)
2009 Ford F-650 24...
