Samsung LCD TV
   / Samsung LCD TV #11
Larry,
Check your cable connections all the way to junction box on the outside of your house, I had the same problem and it turned out to be a bad connector on a cable.
Maybe I shouldn't post this cause it sounds like you want a new TV:D :D - new toys are good
Bob
   / Samsung LCD TV #12
I've checked all the connections and each is very tight,., This has been going on for almost a year, little by little, the channels are losing sound. In any case, can someone tell me which is better to have, a DLP or LCD. Is ther that much difference, I see on the net that most LCD are not cable digital compatible, Not sure if this is important or not, We have Cox digital cable,, thus the question.
   / Samsung LCD TV #13
If you have a Tweeter's nearby I'd go there. They are usually very well trained and knowledgeable on the product they sell and are willing to help.
If I was buying today I'd look at one of the wall mount LCD's that accept a 1080p input at both 24 and 30 frames/sec. (film is recorded at 24 and TV at 30) this will kep the set from being obsolete for a couple of years, since the new formats (Blu-Ray & HD-DVD) and players are starting to output these signals. Unless I'm mistaken any of the newer mid-range and higher sets should accept a cable digital signal and decode it. (As a general rule if the set has an over the air tuner for HD broadcast signals it should accept the cable).
Personally I like the wall mount LCD - 60,000+ hours on screen and wioth the newest technology no motion atifacts.
Bob
Two Pairs of 8ft Fork Extensions (A55787)
Two Pairs of 8ft...
2010 Club Car Precedent Electric Golf Cart (A53424)
2010 Club Car...
2014 INTERNATIONAL 4300 INSULATED COLD BOX TRUCK (A54607)
2014 INTERNATIONAL...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A55788)
2014 Ram 1500 4x4...
2017 SKYJACK SJIII4740 ELECTRIC SCISSOR LIFT (A52705)
2017 SKYJACK...
2008 Hitachi PC228 (A47477)
2008 Hitachi PC228...
