Tractor Sizing Same Size?
   / Same Size? #11
I'm not sure why you are moving up one size of tractor but you might not find that much of a difference moving up from a B7610 to the B7800/2630 or 3030.
Knowing what I know now about my actual needs I would have gone up to a L series
   / Same Size? #13
Big Dad,
The B2630 is powered by a B7610 engine that's been tweaked for a couple more ponies....they're both the same displacement but the B2630 is rated to run at higher RPM. If you liked the 7610's powerplant, you'll like the 2630. But if you want a meaningful boost in guts (torque) you'll have to go to the larger engine in the B3030 or B7800.
As much as I like the B7800, I'd probably go for a 2630/3030 to get the Position Control on the 3pt. The Quarter Inching on the B7610 has been found wanting on a couple of my jobs so far and is the only complaint I have about the tractor. When bush hogging or box blading on rough, uneven ground; it's a let down.
The only negative with the 2630/3030 that I see is the bug-like look. They look like box store riding mowers while the old-school B7800 looks like a tractor should.
FWIW
Bob
   / Same Size?
Went with a B2630! Although I only had 15 hours on the 7610 and 2 hours on the 2630 got yesterday I am way glad I went to this model. Seat still sucks every other feature rocks!
Thought about going with the 3030 but I dont use PTO much and 26 hp is plenty for me. It is much larger than the 7610 so it will take some getting used too, wife had heart attach when they delivered it. I forgot to tell her I made the trade and I wasnt home.:eek:
   / Same Size? #15
You did not tell the wife you made the trade?:confused: GOOD LORD MAN DO YOU HAVE A DEATH WISH???:D
   / Same Size? #16
Big Daddy M said:
...... Seat still sucks every other feature rocks!
That will be covered for your machine, under the PSB. A replacement seat for little of nothing, from what I have read here.
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A55787)
2014 JLG G12-55A...
2021 CATERPILLAR 926M WHEEL LOADER (A52705)
2021 CATERPILLAR...
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
GRADALL XL4100 IV MOBILE EXCAVATOR (A51406)
GRADALL XL4100 IV...
2017 Ram 4500 Bucket Truck (A55218)
2017 Ram 4500...
2007 Honda CR-V SUV (A53424)
2007 Honda CR-V...
