Same Frame Size?
/ Same Frame Size? #1
arnoldziffel
Branson 4225h, Mahindra 2516, several Toro Wheel Horse 522xi machines.
I recently learned of a used LS J2020h tractor for sale from my out of state cousin.
I'm considering buying it.
Recently I looked at an LS J2023h (new at a local dealer).
Are these two tractors the same physical size? I'm very tall and I felt the J2023h could work but I wouldn't want anything smaller. Given that I may make a long distance, sight unseen, commitment to buy the J2020H, I want to get some sense of the ergonomics.
Any other size, power, loader differences between the two worth noting?
We plan to use this as a second tractor for 5 acre 3 point finish mowing only. (Can a J2020h power a 5' finish mower?) The loader would be dismounted and stored in our barn.
Thoughts?
Thank-you.
/ Same Frame Size? #3
There appears to be a slight difference in overall weight of about 20 pounds and a different engine in the 2030 but otherwise same frame, tires etc. The 2023 also has a different loader (per website from the 2020 / 2030 which is a bit strange although it is perhaps a typo and meant to be a different loader on the 2030 rather than the 2023/2020.
I would say that if you fit on a 2020 you will fit on any of the other two.
/ Same Frame Size?
I didn't buy the J2020H as I determined, (based upon my close inspection of the similar J2023H), it was too narrow for our needs.
I was worried that such a narrow model would be tippy. Even though our land is largely flat, I didn't want to risk it. (I will say that the J2023H does represent a solid value for folks not concerned with narrowness).
Fortunately, there are other wider small tractors in the marketplace.
/ Same Frame Size? #5
The 2023 has a higher loader capacity, larger hydro pumps, and a few more HP than the 2020.
I bought a 2023 brands new and I've been very happy with it. I use it on 6 acres. It will easily run a 5ft finish mower.
My 6 acres is very hilly and there has never been a time i was worried about tipping. Seems like a trivial issue to sway your decision if your property is mostly flat.
/ Same Frame Size? #6
Physical size of just the tractors are the same. The loader on the 2023 is a good bit heavier (300lbs) The 2023 also has a larger hydro pump which gives it a little more lifting capabilites. The 2020 shouldn't have a problem handling a 5ft. finish mower.
2018 Kenworth T800 T/A Sleeper Cab Truck Tractor (A64194)
2018 Kenworth T800...
2022 EZ-GO ELITE...
2026 SDLANCH SDLC2020 High-End Carport (A64194)
2026 SDLANCH...
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
Case 1150G Crawler Dozer (A66285)
Case 1150G Crawler...
MASSEY FERGUSON 28 BLADE DISC HARROW (A64278)
MASSEY FERGUSON 28...
