SAME Argon 50 steering ram leak: Repair at home or not?
   / SAME Argon 50 steering ram leak: Repair at home or not?
The new (blue) seal was an absolute bastard to get in. I ended up having to grease it to get it into position after much cursing!
I cleaned up the corrosion on the end cap with the wire wheel on my bench grinder.
The mosquitoes drove me out of my workshop and into the house this evening.
Re-assembling tomorrow!
   / SAME Argon 50 steering ram leak: Repair at home or not? #13
Good job on fixing it yourself!
SR
Mission accomplished!
I was surprised at how simple the ram is internally.
The hardest part of this job was the tight fit of the seals making them hard to fit in place.
I had to do a bit of improvisation here and there, but we got there in the end. ;-)
   / SAME Argon 50 steering ram leak: Repair at home or not? #15
Thanks for the picts., I have one leaking too...
SR
   / SAME Argon 50 steering ram leak: Repair at home or not? #16
Do you have one (left) or 2 steering cylinders?
I had idea to install second (right) one too, as never Same’s have.
   / SAME Argon 50 steering ram leak: Repair at home or not? #17
My tractors only have one steering cylinder, and I have not repaired the one that's leaking, yet...
SR
My SAME Argon 50 has only one steering ram, on the left side.
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
(APPROX 100) UNUSED LANDHERO T-TOP BOLLARD (A51248)
(APPROX 100)...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
RIDGID K-400 POWERED DRAIN CLEANER (A51248)
RIDGID K-400...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
