Same 80 Explorer Transmission Fluid Top Up
   / Same 80 Explorer Transmission Fluid Top Up #1
pjpnzl
New zealand
Same 80 Explorer
Where on a Same Explorer 80 do I fill up the transmission fluid?
Thank you.
   / Same 80 Explorer Transmission Fluid Top Up #2
Fill pug on top at rear 3 pt hitch, lift and transmission are one system
   / Same 80 Explorer Transmission Fluid Top Up #3
I believe you have to have the 3 point all the way down, for proper fill level check.
SR
Thank you.
Hard place to get to on my Same. Behind all the hydraulic connections etc!
   / Same 80 Explorer Transmission Fluid Top Up #6
G'day if you talk to your local dealer they should be able to supply you with an owners manual
Jon
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
1972 Volkswagon Beetle (A51572)
1972 Volkswagon...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2005 Reinke 48ft Stepdeck Trailer (A51572)
2005 Reinke 48ft...
2015 Ram 4500 Utility Truck, VIN # 3C7WRKAJ9FG707673 (A51572)
2015 Ram 4500...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2018 FREIGHTLINER...
