Saltwater boat trailer brakes eaten alive
   / Saltwater boat trailer brakes eaten alive #1
Chain Bender
Kubota L3200
Have had the trailer for 4 years. New when I got it. Magic Tilt aluminum tandem axle with front axle brakes.
I take good care of my stuff. Really good care. I usually cary 2 five gallon buckets of fresh water to the ramp with me so I can at least spaash some fresh water on the brakes so they don't sit in salt for 8-10 hours while I'm out fishing. I always and I do mean always stop at a local car wash about 1/2 mile from the ramp and wash the boat, trailer and truck on the way home. It's only $5 for as long as I want to use the stall. The brakes are the first thing I hit with warm high pressure soapy water. Then they get two more good rinsings before we leave for home. As soon as I pull into the back yard and back the boat down hill I rinse the brakes again while everyone is getting their rods and stuff out of the boat. Flush the motor and rinse the brakes again. I let the boat sit out in the dew over night and then pressure wash it one more time and hit the brakes again.
Last Thursday I caught a glimpse of sparks coming of my left brake while traveling. No brakes applied. Touched the brakes and it did it again and worse. It was dark and I couldn't find anything loose or even warm, much less falling off or hot.
Long story short, the brakes are totally eaten up. Caliper flange is about to break away from the axle, rotors are severly pitted.
I'm trying to figure out how to fix this mess and after looking at the caliper flanges I'm not exactly what I need to do....short of replacing the complete axle assembly and new aluminum/SS/galvanized parts.
Anyone have any suggestions where to start? I'll probably go ahead and replace both pairs of leaf springs while I'm at it too.
thanks in advance for any suggestions,
CB
   / Saltwater boat trailer brakes eaten alive #2
Were the brakes galvanized or stainless to start with? I deal with tons of boat stuff and what little salt water stuff I have been around a common item is rust, no matter how good you rinse and such. Your bearings and races will probably be just as bad. Sorry, just life in the salt.
Chris
   / Saltwater boat trailer brakes eaten alive #4
I personally would not wash trailer brakes while they are warm from driving. It's almost as bad as not having to wait in line at the boat ramp and dumping your brakes right in the cool water after getting off the highway. Rotors don't form pits from routine wear, they form from heat fatigue in the metal.
   / Saltwater boat trailer brakes eaten alive #5
Rotors also pit from salt as anyone in salt country knows. Its worse on highway driven cars as the rotors don't get heated up and dried out. The rears on cars/trucks are worse for the same reason.
   / Saltwater boat trailer brakes eaten alive #6
We just had to replace all 4 calipers on our boat's trailer after 6 years - we were able to save the rotors. We were not as careful as you with rinsing, but we only dunked the trailer twice a year (in salt water). The backing on the brake pads seemed to be the biggest problem - it swelled right up and locked the wheels.
I think your experience is pretty normal - remember the trailer manufacturer is going to put the cheapest brake possible on there (meaning not stainless). In your situation, dealing with only one axle, you may want to try stainless brakes, including stainless rotors. For us, doing that to both axles would have been $1400 in parts alone, so we went with the non-stainless and we'll try to rinse better.
Tim
   / Saltwater boat trailer brakes eaten alive #7
Chain Bender,
The rinsing may help, but you will never get all the salt out of all che cracks and crevices. I would just put the brakes on the routine maintenance list and change them out avery few years. We constantly fight rust at out here at work. Even the stainless stuff rusts after a while. All you can do is change everything out then do it again in a few years.
   / Saltwater boat trailer brakes eaten alive #8
One must remember a boat is a giant hole in the water and money must be poured into it to keep it afloat...:D
Signed, a Duckworth River Sled Owner, 21' Mag...
   / Saltwater boat trailer brakes eaten alive #9
BOAT.....Bust Out Another Thousand. :laughing: Sorry, couldn't resist. Mark
   / Saltwater boat trailer brakes eaten alive #10
I have a magic tilt 24 footer from 04. The drums are awful on my trailer
I am changing to kodiak stainless disc brakes when I have some money.
Dump Truck Body with Tarp System (A51692)
Dump Truck Body...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
44029 (A51692)
44029 (A51692)
