WranglerX
Super Member
MY MF GC 1715 has seat safety switch and only kills motor when I leave seat and HST is still in gear..... Biggest pain for me is bumping any lever and engaging something like mid mount PTO lever and its out of neutral position and machine won't start (mid mount PTO has no implement attached and is never used), I have to go over all the lever to ensure all are correctly in neutral) probably need "position locks" for unused levers ... It's a learned procedure like when stopping to get off tractor or shifting into neutral ALWAYS set brake first... When HST in neutral you have no (trans/engine) braking or control you normally have through HST... Something it can be a bit startling...
Conversely when I bought my property there was a JD L120 riding mower mixed in deal... It has seat safety switch disabled and reverse lockout/bypass switch wired around so it would mow in reverse without having to hold down push button...
Lockout can be good or bad but one should try to work with them if possible ...
The real enemy here is lawyers and litigation, that is why manufacturers try to make machines "idiot" proof, much to consternation for educated/intelligent users...
Dale
Dale
