Safety doesn't care if your forgetful
   / Safety doesn't care if your forgetful #1
cdaigle430
Maine
MF GC2410
Hello,
Hope all is well with everyone. Wanted to share a misshap I recently had with my tractor.
Took the tractor out of storage last week. Had it in the shed with a trickle charger and the ROPS up. To get it out I had to fold the ROPS but I dropped one of the pins behind the BH and couldn't find it.
Drove it around the property a little and then parked it in the garage for maintenance.
My wife's son and I looked for the pin in the yard and found it, he wanted to know what it's fore so I put the ROPS up and just inserted the pin just to show him.
Two days later I started up the tractor and went behind it to raise the stabilizer arms. While the arm was going up thats when the pin fell out and hit me on the head.
Saw stars and heard ringing on top of the extreme pain on my head for a couple minutes. A week later it's still discolored and sore.
My lesson is always put locking pins even if your just showing it to someone.
This could have killed me, the ROPS is heavy as heck.
   / Safety doesn't care if your forgetful #2
Yup one of those I find it or fix it later...think most of us been there. ;)
   / Safety doesn't care if your forgetful #3
Might want to get checked for a concussion.
   / Safety doesn't care if your forgetful #5
I was taught bolts or pins are to be removed or fully installed, never left finger tight or "temporarily" put in.
it wasnt the pin that hit me on the head it was the ROP. Man thats heavy-I did not go to the hospital because it was a small lump, no bleeding . I didnt get a headache either. So far so good I think.
   / Safety doesn't care if your forgetful #7
If you remove pins often, maybe you need to put them on a leash so the don't get misplaced....
I have done that. Some of my attachments came with the hairpin on a small rubber "strap" so they don't get lost.
   / Safety doesn't care if your forgetful #8
confusion was from this part
yeah a ROPS hitting you is much worse, you got lucky. I got nailed close to eye when I was working on a MF1532 (that rops folds even w/o backhoe) and the old clip fell out of pin w/o me knowing and as working on it pin vibrated out. I heard a clang looked up saw rops coming at me. bled/seeped for few hours bruised for a week.
damn close and I learned from it. not only put clip in make sure clip is good.
   / Safety doesn't care if your forgetful #9
Thanks cdaigle430 for the reminder,
Probably all of us have made an omission like that, and a reminder is always a good idea - thanks.
From a bad experience I had a few years ago, (nothing to do with farm machinery) I suggest a medical examination. Though the injuries I sustained did not include a head injury, the doctors who are responsible for issuing the medical qualification I require (pilot) were certain that "I must have had a head injury for all the other injuries I sustained", and it took literally years to prove I had not. I succeeded, but learned along the way how fragile our heads are, and how injuries can make themselves known in a worse way, months and years later. Detail won't make this a better discussion, I wish a good head examination (probably an MRI) for you, for peace of mind...
   / Safety doesn't care if your forgetful #10
The ROPS makes on hell of a club. You must be llivin right. You are very lucky. Glad you are ok --so far. I am guessing you will tether the pins now. However, tethering will not steady the rops, just keep them from getting lost. Also you will probably take the time to insure they are in place next time. I think we all do simple, but stupid things like that. Rops works better with the pins inserted. - Ha.
   / Safety doesn't care if your forgetful #11
Hello,
When i injure myself, i always think of a hundred ways i could have avoided it. I wear many scars to prove i am a do-it yourself, forgetful, human. Plus I always look to see if anyone saw me…
   / Safety doesn't care if your forgetful #12
yup...no way to make the accident look like a fishing tale if you are seen.
   / Safety doesn't care if your forgetful #14
A ROPS with a single pin? That's a first for me.
   / Safety doesn't care if your forgetful #15
My wife says I am accident prone, I don't know, maybe. I get cut a lot. I was at a doctors office one day about a year or so ago and a nurse was doing the weight and blood pressure thing. She mentioned all the scars and I said hell, those aren't scars you should see my legs. She got all serious and said that we have to report your cutting to the doctor.
I got confused and upset, took a bit to convince her I was not a cutter but a farmer and small cuts are common and I scar easy.
   / Safety doesn't care if your forgetful #16
If you repair cars for a living, there are opportunities to make these kinds of mistakes all day. So, a good rule of thumb is to always avoid a situation where you start to do a particular task, but do not complete it.
Another example would be, don't put a wheel on a car, unless you are going to complete the task, and fully fasten that wheel, at that time. It's easy to see that a wheel isn't on the car, and remember you need to put it on, if you got distracted. But, it's impossible to see you didn't fully tighten the lug nuts.
   / Safety doesn't care if your forgetful #18
dropping a few transfer cases on chest and dodge 318 onto foot (foot between engine and frame had to lift engine by hand to free it. that hurt ) come to mind.
sadly the engine and 2 of the 3 transfer cases on chest (last one 2017) were in front of witnesses so I could not make up a "fishing" story about it them.
   / Safety doesn't care if your forgetful #19
I learned some time ago to check twice and then safety wire, brace or block off. Anything that can bite you will. I have 4 stacks of short 2x6s and 8s that I use to support tractor attachments.
Contractors wanted to burn everything, I cleaned up the shop and house build site every day.
   / Safety doesn't care if your forgetful #20
And....the guy I do some work for put a wheel on a car last Thursday, and didn't tighten it. 🤷‍♂️
Funny, I was just talking about that..
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
2009 CHEVROLET C8500 CREW CAB FLATBED TRUCK (A59823)
2009 CHEVROLET...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A60432)
UNUSED RAYTREE...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
