farmboy12
Platinum Member
- Joined
- Feb 18, 2008
- Messages
- 908
- Location
- Benedict, MD
- Tractor
- Kubota M4900 FEL; New Holland TC30 MMM; Ford 1620; Ford 1520 MMM; John Deere X740; John Deere 455 MMM; Craftsman 19.5hp;;;;; Antiques: 1946 John Deere B; 1951 John Deere MT; 1952 Allis Chalmers B; 1967 International 140
the problem is that you cannot get off fast enough and get clear when the proverbial manure hits the fan, last year I rolled a Cub Cadet lawn tractor (~20hp, 50" deck hydro tranny), I was going up a 30/45 degree slope and the back (turf) tires hit a slippery patch, the tractor started to slide backwards and by the time I could react I was on the downhill side of the tractor and it was on its side, I got up and pushed it back upright, then shut off the motor (I have the motor kill switch disabled, but the deck kill switch works, it shuts off the deck if you get off the seat, then you have to turn it off and back on for it to turn on again)
The whole sequence of events from when the wheel started to slip until I was on the ground was 2-3 seconds, if the edge of the deck had not dug into the mud the tractor would have gone all the way over onto me before I could have done anything.
If you are on a tractor with ROPS and try to jump off odds are that you will end up pinned under something, also if you hit a bump (like the person in the accident at the start of this thread, it is very possible that you could fall of the tractor and get run over or entangled in whatever implement is behind the tractor.
If you are on a ROPS equipped tractor using a seatbelt you are far more likely to walk away from an accident than on a non-ROPS tractor, or than on a ROPS tractor without a seatbelt (the same goes for seatbelts on cars)
so, do your parents a favor and wear a seat belt, because (to me, no offense to anyone here or anywhere) the only thing worse than dieing in a tractor accident would be to be live and be paralyzed from a tractor accident.
Aaron Z
Sure, in cars going 70mph and colliding. You don't just start to roll over, unless on very steep hill. When you're just moving your car a few feet in the driveway, do you put your seat belt on? 95% of truthful people will say no. When you're going that same speed, of say, 3mph, you don't even think about it. It just comes back to the discussion discussed dozens of times on TBN "Why you should wear your seatbelt." Let's not get into this again.
Everybody has different ways in doing everything, and although some of you guys and me may not be offended by stuff like this, someone may be offended, and we do not want this.
Kyle
