Safe to start?
   / Safe to start? #1
Rainman9476
Massey Ferguson 205-4
I have a Massey Ferguson 205-4 normally I keep the stack covered, however the boys knocked the can off. We had a good rain so im sure water got in. Is it safe to try and start? If not what do I do
   / Safe to start? #2
I can't imagine there would be much water in there, in a short time.
If you want to find out, you can remove the glow plugs, if it is a diesel, or spark plugs if it isn't, and crank it. That should pump it out.
   / Safe to start? #3
If you think there is water in the cylinders try turning the motor over by hand and see if the engine locks up.
   / Safe to start?
thanks i will give it a try guys
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
(1) 330 (1) 300 GALLON POLY TOTES (A51248)
(1) 330 (1) 300...
2014 TAKEUCHI TS70R SKID STEER (A51246)
2014 TAKEUCHI...
2017 Kubota KX080-4 Mini Excavator (A51573)
2017 Kubota...
2014 Dodge Grand Caravan SE Van (A51694)
2014 Dodge Grand...
