safe start switch locaton on 454 foton tractor
   / safe start switch locaton on 454 foton tractor #21
Thanks for the info. The switch is mechanical, when you press the brake it allows the switch mechanism to open. I will trace the wires back from the terminal to see where it goes...its been so cold so hopefully it will warm up soon so I can give it a good look. Will keep you posted.
Also, I did determine the sensor on the bell housing was my tach. It is not working...I unplugged it just to see if there were any changes but nothing.
Regarding your tach pickup. If you unscrew it and take it out, you will see it is an enclosed magnet. It can get very dirty and if you see little metal chips etc stuck to the end,, it will need cleaning. Wash it with brake cleaner and get everything of. Replace it into the threaded hole and screw it in until it just touches the flywheel. Then back it about half a turn and lock it in position - this should give you the approximate clearance you need. To confirm it is not hitting anything, bar the engine over by hand and feel for any impact. This should give you the setting for the pickup to work. Also look for any disconnected wires on the tacho. When you are sure the flywheel doesn't meet the pickup, try running the engine. if it doesn't work then maybe a new sender is required (pickup). They are not expensive, but try the cheap fixes first.
Thought I would post a update. There is supposed to be a clutch safety on this tractor. I followed the wires back from starter and I can see where the wires have been jumped. Previous owner obviously took the safety switch off. There is supposed to be two switches underneath the clutch. One is a break switch and the other is the clutch safety switch. I don't know much about wiring so I may try to put a switch on it once I do a bit more research. Thanks for everyone's help!
   / safe start switch locaton on 454 foton tractor #24
hagrant,
Thanks for the posting, I have been wondering about it. Please post what you do about that safety switch when you have figured it out.
   / safe start switch locaton on 454 foton tractor #25
The switches being in just about the worst location to catch water, snow and road salt it is no wonder they were removed.
Great location for southern climates, not snowy N.B.
Every tractor I know of no longer has those switches in my area.
Yes, they are in a terrible location for snowy climates. I will post any updates on this issue. This is a great forum!
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
2022 ISUZU NQR 18FT FLATBED (A51222)
2022 ISUZU NQR...
John Deere 270 Compact Wheel Loader Skid Steer (A50322)
John Deere 270...
JLG 1255 Telehandler (A52128)
JLG 1255...
2014 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A50854)
2014 ORTEQ ENERGY...
HANG ON 48" CATERPILLAR FORKS (A51242)
HANG ON 48"...
