SAE 30 or 10W-30 for older IH FARMALL
   / SAE 30 or 10W-30 for older IH FARMALL #21
Yup,
In 1972 we didn't have as many choices' heck back then if an engine had 100k it was practically worn out.
   / SAE 30 or 10W-30 for older IH FARMALL #22
30w will cover summer use.
   / SAE 30 or 10W-30 for older IH FARMALL #23
Every good oil thread runs at least 5 pages. The old gal will probably just be appreciative of an oil change. Post a pic. Enjoy your new ride!
   / SAE 30 or 10W-30 for older IH FARMALL #24
I was in a Rural King the other day and saw some 30 weight oil that was rated SL which means it has the higher zinc content these older engines need. The right oil for that tractor is one with the older ratings and not one of the newer oils likely to starve the engine the zinc it needs to survive.
   / SAE 30 or 10W-30 for older IH FARMALL #25
Yes,
Zinc is important n the older engines and the solid lifter engines have to have Zinc in order to survive.
Thanks guys for all the back and forth I really appreciate it. I think I’m going with SAE 30 for now (what the manual calls for) The others probs would work but why chance it. Here’s a few picks of the old gal, hope to pretty her up this winter just like the old sales brochure! Happy holidays to all…I know some of you are saying after all that going with spec oil 🤣
   / SAE 30 or 10W-30 for older IH FARMALL #27
Is that power steering?
   / SAE 30 or 10W-30 for older IH FARMALL #28
The 140 is a great and classic tractor worth caring for and slightly restoring to original condition and intent. High quality original workmanship and pride with lots of parts and donor tractors widely available. Correct paint would be nice if done right. Use OEM paint when you know how to do it.
You'll need to pack those front wheel bearings and replace grease seals. Keep trans gear oil at correct level since it likely leaks out. Use thicker oil. Keep the kids away from it, especially when operating, until you are more familiar with things. People expect the safety protections of 2021 but that tractor is likely before your father was born.
Best to find a group or site with people that specifically adore older Farmalls like this and better understand some of the ins and out of things. For example, you want to make sure the gear oil you put in the trans is compatible with any bronze bushings you may or may not have. I know this is an issue with some older smaller tractors but not sure on the Farmalls. These tractors are easy to maintain, solidly built and will purr like a kitten when tuned right, which is easy.
Send, and keep sending more pics.
   / SAE 30 or 10W-30 for older IH FARMALL #30
Modern 10w30 oils do not have the zinc needed for old engines with flat tappets. Most cam companies recommend a 15w-40 diesel oil for the higher zinc content.
I would suggest Rotella 15w-40w as it has zinc. If you use the other it will eventually flatten you cam and wear out your lifters.
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53472)
2020 New Holland...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2023 GMC 3500 Bed (A51573)
2023 GMC 3500 Bed...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
