sack of firewood
   / sack of firewood #1
Agvg
Elite Member
Norway
Mf135, Ursus C-355, David Brown 995
   / sack of firewood #2
Looks real handy. I have seen those sacks used for aggregate materials.
   / sack of firewood
Today this is the most common way to store firewood in Norway.
   / sack of firewood
My wood
Sitting there for a few years
   / sack of firewood #7
So when you go to use the firewood do you take it out of the bag piece at a time, or do you cut the bag open?
   / sack of firewood
Those on the last pictures are for onetime use, if you are carefully you can reuse them once more.
The net on pallets is open at top and bottom so they are easy to pick wood out of for daily use.
   / sack of firewood #9
That's very interesting.
The winters here on the western side of the state where i live, are very temperate but also very wet. If i don't keep mine off the ground and undercover, it get saturated with water then molds and rots. There is a distinctly unpleasant smell when burning wood that has fungus thru out the wood. Not to mention how much heat is needed to dry the wood before it burns. On the eastern side of the state, it's much colder and dryer and storing wood is very easy. You can just pile it up outside and it stay dry and ready to burn.
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A55218)
Greenworks...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
30pc. 16ft.x 3ft. Brown Metal Roof/ Wall Panels (A53424)
30pc. 16ft.x 3ft...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
