Saber Samurai Cutter
   / Saber Samurai Cutter #1
NC419N
Kubota BX2670 Kioti NX5510C Ford 3000 ford 4500TLB Ford 9N Farmtrac 555DTC New Holland 1720 New Holland 2120 Kubota BX22 Kubota ZD1200
Anybody on the forum used one of these? Experiences ??
   / Saber Samurai Cutter #2
I have one. I clamp it to my bucket and mostly use it to trim paths, beside the pond. Works great although not perfect.
   / Saber Samurai Cutter #3
This thread is relevant to me.
I'm planning on purchasing one just not sure on brand.
Procut vs saber samurai.
Edit procut is available in 4 different bar lengths 42,54,66,90 inches and claims USA made
What’s the “not perfect “ part?
From the specs it looks to check most of what I would want it to do.
The procut has less capacity for the smaller size and not sure 54” or larger would be as easy to maneuver
   / Saber Samurai Cutter #5
First check out the hyd. system flow rates required.
   / Saber Samurai Cutter #6
   / Saber Samurai Cutter #7
Cutting is fine, it is a bit heavy and has a spring loaded flip latch. Designed so that if it hits something too solid it will flip back, or forward depending on which direction its pointing to. I had to tweak/tighten the trigger and not sure if its right just yet. I only use it for trimming around fields, paths mainly, hadn't used it since last fall or so.
I do plan to try trimming around the edge of my pond. I have flipped it to the horizontal direction and used it seems good what little i used it for. I was cutting limbs about 1/2-3/4 with it. You definitely want to be running the cutters before engaging the material to be cut. It can stall out if you start with that material in the cutter. Just makes sense though.
My kioti hydraulics seems to handle the cutters fine. I do need to trim around the paths again soon.
Later in July early August I will try and use it to trim the grape vines back. We do that prior to having pickers. That way they can see the fruit.
Update
Getting assembled was no problem spring loaded latch still needs more adjustment. Cutting is going to take some practice to figure out best method. Main thing is the third function button wearing our my thumb:)
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
20702 (A51694)
20702 (A51694)
20711 (A50323)
20711 (A50323)
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A53843)
2013 XLR...
2021 Club Car Carryall 500 Utility Cart (A55851)
2021 Club Car...
