S373 (maybe others) aftermarket single wire alternator
   / S373 (maybe others) aftermarket single wire alternator #1
GrocMax
McKinney TX
Satoh S373
The S373 had a fried alternator and fried regulator and wiring harness when we got it. While these parts seem to be available they are a bit pricey. Since I had to pretty much build a new wiring harness it was decided to put a single wire alternator on. Simple install but you will have to make spacers, cut the housing boss, and make an upper bracket to align pulleys, and I had to cut down the back of the pulley to get belt alignment correct. No provisions for charging lamp on this unit, but you can change the internal regulator (costs as much as the entire alt) if you really want it.
Amazon.com: DB Electrical AND525 Alternator (Fits Chevrolet Gm Mini Street Rod Race One-Wire High Per Formance Alternator 35 Amp): Automotive
This is the one installed. Starts charging at about 1200 engine RPM with the supplied pulley but if you can find a smaller pulley should work at idle. Doesn't hurt anything as there is about zero electrical draw on this tractor and very little time is spent at idle. Only needs one wire from alternator + terminal to the starter + lug. Requires different length belt.
Amazon.com: Db Electrical And212 Alternator For Chevy Mini Alternator For Denso Street Rod Race 3-Wire,Case Trencher Uni-loader Grasshopper Tractor,Gravely Tractor,Kubota Excavator,Tractor,Loader,Mower: Automotive
This one might be better for some applications, has provisions for the charge lamp, but whether it will fit easier is unknown. I suspect the alternator cases are the same with different internals and the 3 wire regulator.
   / S373 (maybe others) aftermarket single wire alternator #2
My local starter/alternator shop put a one wire on my Buck. I have a voltmeter on it and usually bump the throttle to make it charge.
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A52377)
2021 Freightliner...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
2005 Mitsubishi Lancer ES Sedan (A54815)
2005 Mitsubishi...
