S370D Ext. Hyd. Adapter
   / S370D Ext. Hyd. Adapter #1
CharlieatDelphi
Am mounting a front snow plow. Need the External Hydralic Adapter for the Hi pressure line. New or used. Thanks
   / S370D Ext. Hyd. Adapter #2
I think that all you will need is a hydraulic hose that fits in the plug located under the seat area. I think this plug is tapped for standard american pipe taper, but I can't remember the size. Take the plug with you and go to your local Colliflower, or hydraulic hose shop, and they can make the hose for you. This is for one way hydraulics, linked to your existing lift system (it uses the lift controls for lifting the 3 point arms). I plugged a hose into the port for lifting a pull type aerator, and it works just fine for that purpose, just put a quick disconnect fitting in the hose line, so you can separate from the plow quickly.
diyDave, thanks for the prompt reply. I am planning on using a double action cylinder. Will look the plug up and check out it's possibilities.
My only other options is to cut the Hi Pressure line and splice into it.
   / S370D Ext. Hyd. Adapter #4
Charlie, there are at least two good vendors here that can provide what you need. Len at Shaeffer's and Bill at Valley Power (satohparts.com). If you read enough of these threads you'll stumble on to their contact info.
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
Broom Attachment (A59228)
Broom Attachment...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
