S-650G Timing Info
   / S-650G Timing Info #1
Darkghost
I just rebuilt my S-650G and need some help with the timing. I see there are 2 hashes on the crank, but they are not marked. my book doesn't show anything on the timing, or specs.
I was also wondering what the valve adj. order should be.
Thanks.
   / S-650G Timing Info #2
I have a repair manual and it states that the timing is supposed to be set with timing mark coinciding with the pointer. However, like yours mine has 2 notches. I tried it at each point and then actually adjusted by how the engine ran from there. I found mine ran better at all rpms when it wasn't on either mark. I don't remember where I ended up setting it.
I can't seem to find any order in which to adjust the valves. It just says to adjust each cylinder at TDC. Hope this helps
Thanks, it looks like we have the same book, lol. I ended up just playing it by ear, and it runs great.
2017 Isuzu NRR Box Truck (A51692)
2017 Isuzu NRR Box...
Tailift 5000 Forklift (A53117)
Tailift 5000...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
40' CONTAINER (A51248)
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
