S-370 Satoh Beaver clutch problems
/ S-370 Satoh Beaver clutch problems #1
green52pickup
I have an S-370 that I cannot disengage the clutch. It's not an external linkage problem, I checked that. How can I inspect the clutch and pressure plate to see inside? How do I diagnose the problem?
/ S-370 Satoh Beaver clutch problems #2
Has the tractor sat awhile? The clutch disc could be froze to the flywheel.
Yes the tractor has sat for a while and your suggestion the clutch and flywheel are frozen together is what I am thinking. How do you suggest I get them apart?
/ S-370 Satoh Beaver clutch problems #4
The pull method. Tie tractor to truck, push clutch in on ( make sure it's in gear) tractor and pull tractor with truck till clutch breaks loose.
