rzt50 pto clutch
   / rzt50 pto clutch #1
inneedofhelp
shelton
cub cadet zero turn
Is there anybody out there who has dealt with trying to remove one ??? I try to take the shaft bolt out and it just spins. I have tried everything, looked all over the internet for pro manuals
. None of them say anything about this problem.
   / rzt50 pto clutch #2
Most repair shops use an impact wrench to remove the bolt from the crankshaft . Just not a good way to hold the crankshaft in most cases. the other method used is to put a wrench on the bolt and then smack the wrench with a hammer to create an impact effect.
   / rzt50 pto clutch #3
one other shadetree trick is to feed a length of 1/4 dia nylon rope into the spark plug hole (leave a bit hanging out) after turning the engine to where that piston is just at the beginning of it's compression stroke and BOTH VALVES CLOSED. The piston will crunch down on the coiled rope in the cylinder as you begine unscrewing the pto bolt with a breaker bar offering the needed resistance to break same loose...
   / rzt50 pto clutch #4
I have done that to chainsaws and trimmers to remove the clutch Actually that is what you had to do to remove and reinstall the valve keepers on select Tecumseh engines because the valve box was installed after installing the head.
   / rzt50 pto clutch
Thanks Randy, The ol impact wrench trick worked. Ordered new clutch, hopefully it will bring and end to this evil experience.
CATALOG UPDATES LOT IDENTIFIER 5 (A53084)
CATALOG UPDATES...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
MachPro MP15Pro Mini Excavator, NEW! (A52384)
MachPro MP15Pro...
HOMEADE PIN ON 2 PRONG HAY SPEAR (A51247)
HOMEADE PIN ON 2...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
JOHN DEERE HX14 LOT IDENTIFIER 259 (A53084)
JOHN DEERE HX14...
