rzt50 pto clutch
   / rzt50 pto clutch #1
inneedofhelp
shelton
cub cadet zero turn
Is there anybody out there who has dealt with trying to remove one ??? I try to take the shaft bolt out and it just spins. I have tried everything, looked all over the internet for pro manuals
. None of them say anything about this problem.
   / rzt50 pto clutch #2
Most repair shops use an impact wrench to remove the bolt from the crankshaft . Just not a good way to hold the crankshaft in most cases. the other method used is to put a wrench on the bolt and then smack the wrench with a hammer to create an impact effect.
   / rzt50 pto clutch #3
one other shadetree trick is to feed a length of 1/4 dia nylon rope into the spark plug hole (leave a bit hanging out) after turning the engine to where that piston is just at the beginning of it's compression stroke and BOTH VALVES CLOSED. The piston will crunch down on the coiled rope in the cylinder as you begine unscrewing the pto bolt with a breaker bar offering the needed resistance to break same loose...
   / rzt50 pto clutch #4
I have done that to chainsaws and trimmers to remove the clutch Actually that is what you had to do to remove and reinstall the valve keepers on select Tecumseh engines because the valve box was installed after installing the head.
   / rzt50 pto clutch
Thanks Randy, The ol impact wrench trick worked. Ordered new clutch, hopefully it will bring and end to this evil experience.
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
(4) Drums of Mixed Fabric Softener/Detergent (A51573)
(4) Drums of Mixed...
(2) Sumitomo 11.00 R22 Tires (A51573)
(2) Sumitomo 11.00...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53472)
2020 New Holland...
