RZT steering is weaker on right than left
   / RZT steering is weaker on right than left #1
galevin
Indianapolis
none
New to ZTR mowers and just bought a used RZT 50 with 430+hours and the right side works great. The left side is weak and has 50% of the power of the right side esp when I go in reverse. Is this something that can be adjusted or is this a tranny that is going bad? Thanks
   / RZT steering is weaker on right than left #2
I can email you a Hydrogear maintenance manual. It includes a purge procedure which might help. I had a similar situation which was significantly improved by suctioning out as much lubricant as I could, replacing it with a full synthetic 20-W50 oil, and purging. This seems to be a common problem with these units.
I pm'ed you for the email. Many thanks.
Gerald
   / RZT steering is weaker on right than left #4
Before you dig in that deep, you may wanna try replacing the drive belt (the one that goes around both hydrogear tranny's and the motor pulley) - these RZT's are fairly famous for left side being weak, for some reason a slipping belt affects the left side more than the right... Steve
   / RZT steering is weaker on right than left #5
+1 also make sure the belt tensioner moves freely. It has a grease zerk. Who knows if the previous owner regularly lubed it.
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
1998 CATERPILLAR 953C CRAWLER LOADER (A52707)
1998 CATERPILLAR...
2022 BOBCAT S740 SKID STEER (A52707)
2022 BOBCAT S740...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A55315)
2-Row Peanut...
1994 International 3800 Bus (A55852)
1994 International...
2008 CATERPILLAR D6N HIGH TRACK CRAWLER DOZER (A52707)
2008 CATERPILLAR...
