RX8030 leaked water from air vent
   / RX8030 leaked water from air vent #1
OzKioti
SE Queensland, Australia
Kioti RX8030 & loader
I had my 8030 (similar to 7320 I believe) parked nose-down on a slight slope, engine running, while I attached a couple of chains to a fence post which needed pulling back into plumb. That done, engine still running, I shoveled some fill into the new void around the post in the ground, and tamped it down with a bar.
All up, around 10 minutes or so, with air con on full cool. Ambient temp was about 25C (77F).
As soon as I released the brake and started moving, a stream of water dribbled out of one of the front left overhead vents. Enough water to splash on top of the instrument cowl and down onto the floor mat where it flowed from one side to the other.
Normal?
Blocked drain?
Bad design?
Tractor is just over a hundred hours since new. I'll phone the dealer when they open up this morning, and see what they say, but just wondering if anyone else has had this happen.
   / RX8030 leaked water from air vent #2
My guess blocked drain.....
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51692)
2022 Big Tex...
2008 Chevrolet Trailblazer SUV (A51694)
2008 Chevrolet...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
UNUSED HURRICANE 20' X 20' ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
