RX7340 backup camera
/ RX7340 backup camera #1
cutthroat
MO
Kioti RX7340PC
Got the backup camera and monitor installed this weekend. It took way longer than I expected, lots of issues. Went with a 9" monitor that supports two 1080P cameras. The new RX7340 has a spot on the back of the roof for a camera and even a fuse that says rear camera (didn't find any cable ran though). There is a metal plate held on by 4 screws. Behind the plate is a ~1" hole with a rubber grommet installed. Taking out the grommet gives you access to the roof. What wasn't obvious until I spent numerous hours trying to fish a cable is this is a sealed cavity that has no access to any other part of the cab or the side pillars. There is a large probably 3" rubber grommet on the bottom of this cavity that you can get access to lifting the roof up from the back. I cut a X shaped slit and fed my cables out of this cavity, this then got me into the main part of the roof, just above the headliner where I could then route cables down the rear pillar. I repurposed the metal plate and mounted the bracket for the backup camera to it. Reused the original rubber grommet with just a slit in it for my cable to fit through, so should be pretty water/dust tight.
I then worked on the monitor. The new RX7340 has bars along the right door for mounting monitors. I used tube clamps and mounted the monitor to the upper tube. Tube is 27mm for reference. For the cable from the monitor, I just ran it up and over the headliner to the pillar where the camera cable already was. What I wasn't expecting and took a long time was getting power. Just below the pillar is a fuse box, I thought I would just use one of those piggyback fuses for positive and connect ground to an existing screw/bolt. What I eventually found was there was no good ground anywhere in that fuse area I could connect to. So, I punted the piggyback fuse idea, and I wound up just running power from the cigarette lighter on the other side of the tractor and hard wiring through this connection. There is a hole with a grommet pre-installed already below the fuse panel, so just ran cable through it. Cable is behind the seat and on the floor, so totally out of the way.
I also found the one time use retainer clips holding the plastic pillar cover and headliner a total pain. There was no way to remove these without destroying them. I wound up drilling them out and have ordered some similar ones, hopefully the color matches or is close. Below are some pictures of the setup.
/ RX7340 backup camera #2
Nice install. Been going to do that on My 7320 but gotta decide if I'm gonna replace it with a 7340 first 😂
/ RX7340 backup camera #3
What did you use for a camera system? I also want to add a camera to the loader for better visibility when trying to hook on to my attachments.
Went with this one from Amazon.
Amazon Camera
It does have two cameras, I only hooked up one of them for now. Might wire up the second one to focus on the loader area.
/ RX7340 backup camera #5
Have you used your system while in motion? Reason I am asking is I bought a Chinese wonder similar to this one from Amazon (XRoose) but the update frequency of the display is poor while in motion (nice and clear in a steady state condition. Takes a second or 2 to update before you see the actual motion. Doesn't work like the one in my car. I can't find any specs in the Amazon listing on either yours or the one I bought and nothing was in the installation manual.
Yeah I have no issues with it in motion and in the tractor. I felt confident about this one as well because it is the same one agricameras.com sells on their site just for 3x as much. The only issue is when I had it on the bench testing it. I had lines scrolling on the screen, like a frequency issue. Eventually figured out it was the LED lights in my shop causing the issue.
  • Good Post
Reactions: J&K
