RX7320 rear weights added
/ RX7320 rear weights added #1
bdog
Elite Member
Texas
John Deere 6130M
I did not want to add fluid as we have a ton of mesquite at our ranch and flats are common. My tractor came with R4’s which don’t have any provisions for mounting wheel weights. I did some research and found that Kubota M5 500lb weights would fit in the wheels so I bought a couple and installed them. It was a bit of a chore but I am very pleased with the outcome.
I had to undo the valve stem and push it in so the weight would slide past it but once in it cleared. I then used wood shims to center the weight and hold it in place.
The holes in the weight are 7/8”. I wanted to use 7/8” bolts but I couldn’t find a 7/8” drill bit 10” long to drill down through the weights. I had a 12” 1/2” bit so I used a piece of 3/4” pipe in the hole to keep the bit centered and drilled a 1/2” hole in each of the four locations. I then took three pieces of 1/2” all thread and secured the weight to the wheel, flipped it over, and enlarged the holes one at a time to 7/8” adding bolts as I went.
I didn’t like how the bolt heads set up against the angled wheel.
I went and picked up some wedge or beveled washers commonly used when bolting I-beams together and it took two on each bolt to get the head to sit flush.
Wrestling the heavy wheel back in the tractor wasn’t easy by myself but I got it done. This would be much easier and safer with a helper. If this sucker fell you could be squashed like a bug.
/ RX7320 rear weights added #2
nice job
/ RX7320 rear weights added #3
Nicely done, and good find on the wedge washers. I've though about doing this as well, but am hesitant to drill through the rims.
Thanks. I was hesitant as well but I think it will work fine. The wheels are thick where I drilled somewhere between 5/16” and 3/8” I am guessing. I don’t foresee any ill effects. I drilled wheels for weights on my Branson 15 years ago and never had any problems. When I sold it the buyer was happy it had weights. I will caution though that drilling these was a challenge. 7/8” is a pretty big hole to drill and the wheel being sloped doesn’t make it easier. I also had my skid steer to help move the wheel around while the tractor was sitting there on Jack stands
1977 Dodge B10 Cargo Van (A66736)
1977 Dodge B10...
2016 JAYCO JAY FLIGHT CAMPER (A67714)
2016 JAYCO JAY...
2019 Peterbilt 520 Heil DuraPack Python 28Yd Side Loader Garbage Truck (A68183)
2019 Peterbilt 520...
2003 BOBCAT 331D EXCAVATOR (A65056)
2003 BOBCAT 331D...
1998 TRAILMASTER PUP FUEL TRAILER (A67714)
1998 TRAILMASTER...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
