RX7320 problems @7 hrs on the meter
   / RX7320 problems @7 hrs on the meter
Im so freaking over this POS tractor! Plowing the field today I must've gotten into a soft spot or a bit of a hill where the plow took a bigger bite and the engine lugged down and died. Now it wont restart. Just finishing my 4th pass...so maybe 15 minutes of work. 20190331_113557.jpg
   / RX7320 problems @7 hrs on the meter #153
He would have gotten a low fuel light/alarm.
The only time I have had a problem like this is when I forget to push the clutch in or the PTO is engaged. Usually distracted by something or it dies like his from powering out.
Hopefully he already has it started and is happily plowing. :tractor:
I wish I could get in my field. I took this picture just now to post.
Nope, still isnt starting. I let it set for a few hoping that would help and just went and tried again. It died from bogging down. I dont know why it would be hard to start because of that. It turns over like its trying...like a bit faster that it would on just the starter alone.
Dang Lynn, you werent kidding! That is a lot of snow left, especially if you guys have been getting the 50* days we have been getting. What elevation you guys at there? Can't be too much over 5k feet are ya?
   / RX7320 problems @7 hrs on the meter #156
It sounds like a fuel problem,
filter? can you check for flow from your filter?
or possibly your fuel shut off solenoid.
I don't know if yours is energize to run or energize to shut down,
but you may be able to disconnect and manually set it to find out.
   / RX7320 problems @7 hrs on the meter #157
My house is 6000' elevation. We are only getting mid 30's sometimes low 40's for the afternoon high.
I'm surprised it'll turn over and not start.
   / RX7320 problems @7 hrs on the meter #158
Sounds like a fuel issue, maybe shutoff solenoid, do you have a manual plunger on the solenoid you can push in and out a few times?
   / RX7320 problems @7 hrs on the meter #160
What a disappointment. I'm sorry to hear you're having more trouble. I don't remember but does this machine require the shuttle to be in neutral?
2013 Ford F-150 Ext. Cab Pickup Truck (A53422)
2013 Ford F-150...
UNUSED WOLVERINE MAD-12-12D HYD AUGER DRIVE & BIT (A57193)
UNUSED WOLVERINE...
2015 Peterbilt 348 Jerr-Dan T/A Rollback Truck (A55852)
2015 Peterbilt 348...
12-Ton Hydraulic Bottle Jack (A55852)
12-Ton Hydraulic...
PALLET OF ALUMINUM PARTS (A57192)
PALLET OF ALUMINUM...
2016 John Deere 6110M (A53317)
2016 John Deere...
