RX7320 problems @7 hrs on the meter
   / RX7320 problems @7 hrs on the meter #1
THEPARTYHOUND
Montana
JD 2240 MFWA (SOLD); Kioti RX7320
My new tractor got delivered 3 days ago and I've got 7 hours on the meter. It is blowing and snowing here, 20 below windchill, drifts the size of dump trucks. I need my tractor! I was helping a neighbor get cleared out and noticed that my heater hadn't really started warming up although my temp gauge was slightly above the "normal" marks on the gauge. Called the dealership, got put through to the mechanic who asked me to open the hood, and there was the dealer installed block heater hanging limp and NOT in the block where it belongs! It blew the block heater out of the side of the block. There was glue residue on it. I asked about that and the mechanic said that was how they are installed...glued in! What else is glued together in that engine? Is the head glued on? Oil pan glued on? I'm starting to wonder if I made a mistake here...
   / RX7320 problems @7 hrs on the meter #2
Glued in.. No O-ring with a bracket or anything?
Glued in. No bracket, no O-ring, just glue. The dealership had a mechanic just over the mountain an hour away, so he is on his way. I will see how they put it back together.
   / RX7320 problems @7 hrs on the meter #4
Oh my! Glued in with what, strawberry jelly? I've never heard of block heater not being threaded in.
   / RX7320 problems @7 hrs on the meter #5
There is another thread on here describing the install procedure,
I was thinking it was taped in with a lock tite type of product used to retain the
threaded adapter.
Be interesting how the service mechanic handles it or if it has to get into a climate controlled environment to be reinstalled.
Hope your engine is not hurt.
   / RX7320 problems @7 hrs on the meter #6
There pressed into the block, nothing new or different from many other block heaters. Sounds as if the dealer didn’t get it pressed in correctly, I can understand your frustration, hope they get you going quickly.
   / RX7320 problems @7 hrs on the meter #7
Mine isn’t threaded in either and is pressed in but it has an o-ring and a bracket
That’s mounted to the muffler bolts so it stays put.
   / RX7320 problems @7 hrs on the meter #8
let us know how it goes, glad they sent someone out to take care of the issue
   / RX7320 problems @7 hrs on the meter #9
At 7 hours, they darned sure should send someone out for him. I hope you get straightened out. Myself 7320 has about 450 hours on it and the heater will put you out of the cab.
   / RX7320 problems @7 hrs on the meter #10
That is to bad sorry to hear this.
UNUSED FUTURE MINI PALLET FORKS (A57193)
UNUSED FUTURE MINI...
JOHN DEERE 6000 SERIES BRUSHGUARD (A57192)
JOHN DEERE 6000...
1995 Generac 94A05603S Diesel Generator (A55851)
1995 Generac...
2016 Ford F-250 4x4 Reading Service Truck (A55852)
2016 Ford F-250...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
UNUSED SDLANCH SDLWC WOOD CHIPPER (A57193)
UNUSED SDLANCH...
