cutthroat
So I have noticed two things about my RX7320 that want to see if others behave like.
First, if in Medium, and switch into reverse there is almost always a slight gear grinding noise when it starts to go in reverse. In Low gear there is no noise when switching into reverse. Anyone else have this?
Second, I have noticed when using the float feature of my loader that the bucket wont hold the tilt angle I set it to. It always wants to flatten out. I can put the bucket angle at like 45 and it will hold, but If I want to put it at like 20 degrees it wont hold and will flatten out. Also, even when not using float and I have the bucket at like a 20 degree angle the tractor wont lift itself up, the bucket will flatten out. My NX I could put the bucket at any angle and it would hold at the angle. I know the hydraulics are tight because I have zero drop when implements are left up and tractor is off for long periods of time.
Getting my 3rd function installed here in a few days so don't know if this will change any behavior.
Thoughts?
-Craig
Thoughts?
-Craig
