RX 7320 Check Engine Light/ Will Not Stay Running
   / RX 7320 Check Engine Light/ Will Not Stay Running #1
SmallTimin
South, Mississippi
Kioti 7320 w/ Cab, Farmtrac 300DTC
Like the title days my new, 11 hour week and a half old, 7320 popped a CEL this morning. Started up fine and headed to the woods where I have some trees pushed down by the dozer. Have a 3ph boom with log tongs I use to skid trees. I backed up to a root ball and tried to lower 3ph. I could not get it to go down and after 30-45 seconds of fooling with it CEL came on and tractor sounded bad. Started to head out of woods it died. Will not run more than 30 seconds or so. Idles up when you let off brake then dies. Dealer is apparently closed until Monday. Managed to get it on trailer. Dies during manual regen. Needless to say I知 more than a little unhappy. Any suggestions or experience would be greatly appreciated.
Bran
   / RX 7320 Check Engine Light/ Will Not Stay Running #2
Since the tractor is virtually new and your problem seems to be computer generated there is likely to be nothing mere mortals can do to get you going.
Thanks, I didn稚 think so. I suppose more or less venting frustration. Also wanted to see if any other Kioti owners had experienced anything like this with their tractors. Just disappointed.
   / RX 7320 Check Engine Light/ Will Not Stay Running #4
I just bought a new RX7320, only thing so far, one time the Regen light came on and went in limp mode. At 6 hours I know it wasn't in need of that yet. Turned off, restarted, no other issues. Love it so far.
Oh I loved it too, for 11 hours. I dropped it off yesterday at the dealer. He said it should just be a sensor and I will have it back by the weekend. I sure hope that is the the case. I am not putting down kioti, just the dang technology that manufacturers are required to put on these machines.
   / RX 7320 Check Engine Light/ Will Not Stay Running #6
That is the world we live in now, just had some "ghost" issues on my pickup that no one could explain or fix lol. I'm around 18 hours now, have only used half tank of fuel.
Unfortunately, you are correct. I have a buddy who is a big truck diesel mechanic. He said as soon as their trucks are out of warranty they delete them. He thinks it値l be possible to do on the tractor. I know it is going to be awhile but if it is going to be trouble, I will probably delete it if it is possible. I am not even sure if tuning and reflashing tractor ECUs is a thing, but might be worth the research. Deleting my dually is on the list for sure.
   / RX 7320 Check Engine Light/ Will Not Stay Running #8
They get you squared away?
Got the tractor home about an hour ago. Said that a zip tie that holds some wires for the injection pump was too tight and broke a wire. Have not had an opportunity to do anything but unload and park it. Got the 3rd function on, now have to start grapple shopping.
   / RX 7320 Check Engine Light/ Will Not Stay Running #10
Glad it was something simple.
5-Bottom Plow (A52128)
Ih 1066 Tractor (A50514)
Ih 1066 Tractor...
Bush Hog Mod. 300 - 14 3 pt Blade (A50514)
Bush Hog Mod. 300...
2014 International Durastar 4300 Terex BT3063 30,000lb 63ft Crane Truck (A50323)
2014 International...
2001 VOLVO A35D WATER TRUCK (A51242)
2001 VOLVO A35D...
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
