RV trailer frame for flatbed
   / RV trailer frame for flatbed #21
It folded just forward of the front axle. Most stock trailers have the axles set far back for a better ride. This leaves most of the floor area in front of the axles.
There is a reason each type of trailer is built different. They each serve a purpose. If you need to haul equipment get the right trailer, if you need a camper get a camper, ect. I have been in this business part time since the late 80's. Two things have not changed.
1st, you can't build what you need cheaper than you can buy it.
2nd, 9 times out of 10 a used trailer will cost you more than a new one in the first 12 months.
Chris
Your two points reflect my exact observations.
   / RV trailer frame for flatbed #22
My father has an older 16ft tandem trailer that we use for the small equipment. It needs paint, a new wood deck, brakes (it has non-functional brakes on one axle), an axle upgrade (old MH style that is now defunct), wiring to support brakes and better lighting, non-structural welding, and the tongue needs a bend worked out of it.
I started pricing the parts I need and between wood, wire, lights, paint, axles, brakes, and wheels, the pricing is more than what a new trailer costs. And I need at least a few more feet of trailer for the tractor anyway.
So, on a limited budget (we all are on one of these to some extent) you may be better off saving the few dollars per week that you'd spend on parts, and buy a new trailer. Just like any mechanical monster, these things can easily snowball into a money pit.
   / RV trailer frame for flatbed #23
Exactly. Scrap the old one for $250 or sell it on CL for $500 to some dreamer.
Chris
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2015 MACK GU713 (INOPERABLE) (A50854)
2015 MACK GU713...
MAXUM M-1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM M-1000...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
John Deere MegaWide 567 5x6 Round Baler (A51039)
John Deere...
2017 Ground Hog HD99 Towable Hydraulic Auger (A49461)
2017 Ground Hog...
