Rustoleum lubricants?
   / Rustoleum lubricants? #1
countrybumpkin
Elite Member
Kioti, kubota
Anyone tried any of these, just seen them at Menards while getting some fluid film, wondered if they were worth a darn.
Ended up picking up a can of the gel and a can of the multi purpose just to see how they work on stuff.
   / Rustoleum lubricants? #3
I might want that gel. Let me know what it is like. I have had aerosol cans before that were a sprayable fluid that shortly later thickened into a grease consistency. I loved it because you could spray it, flow/run it and know that once it crept in to the gaps of moving parts and had 5 minutes or so to evaporate the carrier... it thickened up into a nice grease like lube that worked way better than WD-40 alone.
So, please do share your opinion of that "gel". I bet others will have similar interest in it as I do.
I will be using it today, so I will post back this evening.
   / Rustoleum lubricants? #5
hmm interesting - I am not sure why you wanted to compare this to fluid film? fluid film has lanolin. does your can shows whats its made with?
   / Rustoleum lubricants? #6
I never got the impression that he was comparing to Fluid Film at all. If you re-read his original post, he says that while shopping for Fluid Film he came across these new products and wondered how they perform. My interpretation is that he is just discovering a new product and asking if any of ya'all know anything about them.... But I suspect that he still bought the Fluid Film because it is a totally different product/task.
   / Rustoleum lubricants? #7
......sprayable fluid that shortly later thickened into a grease consistency. I loved it because you could spray it, flow/run it and know that once it crept in to the gaps of moving parts and had 5 minutes or so to evaporate the carrier.
Couple of cans of a similar product followed me home from work one day. Great stuff like you said, it'll creep then thicken up into grease.........Mike
   / Rustoleum lubricants? #8
What was it? Is it available retail or is it a professional only product like ZEP?
   / Rustoleum lubricants? #9
What was it?
Can't remember the name, it was a consumer grade product...I think. Only thing I remember is it was called Spray Gel-Lube and it had a paper label because it fell off and I had to write the name on it. Spraying it had the viscosity of water and once the carrier evaporated it was sticky and as thick as white grease........Mike
   / Rustoleum lubricants? #10
Rural King is selling a few PB Blaster products including a garage door lubricant that does just that .... goes on as a spray, then takes a grease like consistency.
P.B. Blaster Garage Door Lube 12 oz - 16GDL
There's also a bar and chain oil spray and a few other types.
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
CRAFCO INC. MAGNUM PORTABLE SPRAY INJECTION PATCHER (A54756)
CRAFCO INC. MAGNUM...
HarbinGer Towable Light Tower (A52377)
HarbinGer Towable...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
378812 (A51573)
378812 (A51573)
2019 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2019 CATERPILLAR...
