Rusted Hyd. Cylinder Tubes...LA302
   / Rusted Hyd. Cylinder Tubes...LA302 #1
Stuckin67
I've come across a 2004 B7510 with very low hours. It has unfortunately lived outside and shows more rust than I would have expected.
The only rust that really concerns me is found at the top of the hydraulic cylinder tubes on the LA302 loader. I can't tell what's caused this...maybe grease is leaking and destroyed the paint or leaves and debris were left sitting and holding water...but the pitting is pretty deep and it will have to be fixed.
Below are a couple of pictures. I suppose this has the potential to become a structural problem. Is it a big deal and how would you fix it?
Thanks.
6cpuz9
6r385j
   / Rusted Hyd. Cylinder Tubes...LA302 #2
Good Mornin',
I wouldn't be concerned about buying it. I would clean it up and paint it after you did. might be worth knocking down the price a little. ;)
   / Rusted Hyd. Cylinder Tubes...LA302 #3
Looks like it has been worked on and somebody put something on it that is not healthy for paint or metal judging by the looks of it.
I ended up buying the tractor below asking price, but never did find out what was sprayed on the loader to corrode the metal so badly.
In order to fix the problem, I want to knock out the pins and sandblast the top of each bucket cylinder. Any suggestions for how to best proceed with this project?
Thanks, AG
3rvwym
   / Rusted Hyd. Cylinder Tubes...LA302 #5
sandblast, denatured alcohol to remove the oils, self-etching primer as a base coat would be my suggestion...
2013 Chevrolet Silverado 1500 Pickup Truck (A53117)
2013 Chevrolet...
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
Paint Dryer, Briggs 5.5 (A52384)
Paint Dryer...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
