rust removal
   / rust removal #1
crash325
Elite Member
Tucson AZ
New Holland TC-45
I know this has been posted before. But 2 searches did not turn up anything.
12 Battery, Borax & charger?? + type of metal.
Its been said Coke also works, anyone tried it??
Thanks for your help.
   / rust removal #2
The battery charger works, all kinds of videos on line with the fine points of it. Tried it once and found some thing I did wrong but it still worked just took longer and more adjusting, didn't have enough negitive posts in the water and had to turn it a lot. Ed
   / rust removal #3
Go to YouTube and search for "rust battery charger". You will get several videos on the subject.
Another option is evap-o-rust. I personally have used it and it works great. It's not cheap at around $20 per gallon but can be reused over an over.
   / rust removal #5
Many of the new chargers may not work for what you have in mind.
Don't know the scope of your prodject but applying phosphoric acid will neutralize rust and leave a coating. Lots of other acids that will also work.
   / rust removal
thanks folks
appreciate your responses.
   / rust removal #7
Depending on what you are trying to clean up, but good old Muratic acid is a cheep rust killer. After I get the majority off with it, I also use a final Phosphoric acid dip to "convert" rust to a stable oxide.
   / rust removal #8
I just restored an old Griswold cast iron waffle iron. It was so rusty I had no idea if it was even good still or not. I just put it in a bucket that was about 75/25 distilled vinegar and water. About 3 days in the solution was bubbling and turning foamy with the water being rust color. I pulled it out and was amazed what a treasure I found. Couldn't even tell the thing was over 100 years old.
If you have the time, vinegar and water works wonders and it's non-toxic.
   / rust removal #9
Another good rust remover is liquid molasses from a feed mill mixed about 8 water - 1 molasses. Works very well over time on is also not toxic.
   / rust removal #10
Diet coke: Non toxic (well you could argue that) and not sticky.
UNUSED (1) 3500# IDLER DROP AXLE (A54756)
UNUSED (1) 3500#...
2018 CATERPILLAR 415F2 IL SKIP LOADER (A52705)
2018 CATERPILLAR...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
BUYERS PREMIUM & PAYMENT TERMS (A54607)
BUYERS PREMIUM &...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2020 CATERPILLAR 299D3 XE SKID STEER (A52705)
2020 CATERPILLAR...
