rust on cylinder ram
/ rust on cylinder ram #1
case685
Southwest Ont. Canada
Hi Looked at a used cylinder today that would be great for a log splitter. Only problem is there's rust on the ram. Its not deep but its enough to have caused the chrome to flake off. Is this repairable/useable without taking it for re-surfacing( I priced it out and they wanted as much as the cost of a new cylinder ) or should I keep looking. Thanks. Gerry
Okay There is a Hydroline cyl 22" stroke, 4" bore with a 1.75" ram for sale on ebay. Would this make a good logsplitter cyl? I know the bore and length are adequate, just not sure if the ram/shaft is big enough.
/ rust on cylinder ram #4
The most common repair I see on log splitters is bent rods. Most 4" bore cylinders have a 2" rod. I believe this rod is too small and will bend. For the price of a new cylinder, I don't buy used.
Thanks I have seen logsplitter cyls for sale with 1.5" rods but the heavier duty ones mostly have 2" rods. Must be a reason for that.
2012 Dodge Charger Sedan (A61574)
2012 Dodge Charger...
2014 Link-Belt 350X4 Hydraulic Excavator (A61572)
2014 Link-Belt...
2006 Toyota Sierra CE Van (A61574)
2006 Toyota Sierra...
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
Coats 1550 3D Wheel Balancer Machine (A61573)
Coats 1550 3D...
2014 Kawasaki 70Z7 Articulated Wheel Loader (A61572)
2014 Kawasaki 70Z7...
