rust on cylinder ram
   / rust on cylinder ram #1
case685
Southwest Ont. Canada
Hi Looked at a used cylinder today that would be great for a log splitter. Only problem is there's rust on the ram. Its not deep but its enough to have caused the chrome to flake off. Is this repairable/useable without taking it for re-surfacing( I priced it out and they wanted as much as the cost of a new cylinder ) or should I keep looking. Thanks. Gerry
Okay There is a Hydroline cyl 22" stroke, 4" bore with a 1.75" ram for sale on ebay. Would this make a good logsplitter cyl? I know the bore and length are adequate, just not sure if the ram/shaft is big enough.
   / rust on cylinder ram #4
The most common repair I see on log splitters is bent rods. Most 4" bore cylinders have a 2" rod. I believe this rod is too small and will bend. For the price of a new cylinder, I don't buy used.
Thanks I have seen logsplitter cyls for sale with 1.5" rods but the heavier duty ones mostly have 2" rods. Must be a reason for that.
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53472)
GOODYEAR SET OF...
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
2023 John Deere 6155M MFWD Tractor (A53342)
2023 John Deere...
2022 Kobelco SK85CS-7 Excavator (A51573)
2022 Kobelco...
2014 International ProStar Truck, VIN # 3HSDHSJR1EN768255 (A51572)
2014 International...
2023 John Deere 408R Sprayer (A53342)
2023 John Deere...
