RUST IN RADIATOR TANK
/ RUST IN RADIATOR TANK #1
09112
N.E. Oklahoma
yanmar 3810, 48 Allis B
I have just purchased a new radiator for my old Allis B. I was informed the top tank was full of rust and it would be more expensive to remedy the problem than buy a new one. I still have the old radiator and am wondering if I was sold a bill of goods. Is there an effective means of safely disolving this rust w/o destroying the core? I'm still not convinced this rad was junk as it holds water, but has not been tested under pressure. Any comments would be appreciated.
/ RUST IN RADIATOR TANK #2
Try sticking a magnet to it and see if the radiator has any steel in it to rust. The rust is most likely from inside the engine block. If so the new radiator will soon have rust in it's tank.
Soak in 50% vinegar and water solution. If it flows good and doesn't leak it may be okay.
Thanks Guy, I'll get on this tomorrow morning and get back to you.
/ RUST IN RADIATOR TANK #4
Is the rad steel? If not i would do a rad flush. Get out what you can and keep an eye on it.
Part of what antifreeze does it not let your cooling system rust so its about time to change it and mabe its manufacturer of it.
I thought I would be done with this before now but work has piled up and I haven't gotten around to it yet. The rad is off the tractor at the moment but I will be putting in some quality time today and try to make this one of my projects. Thanks for the input.
/ RUST IN RADIATOR TANK #6
Ahh the joys of working on older machinery. I had a similar situation for my Avery tractor where the radiator had rust. Getting a replacement rad was all but impossible so I took the radiator off and back flushed it by using some old hose and some PVC fittings to fabricate a connector to a garden hose. Hooked to the bottom of the rad where the pump would typically draw and ran copious amounts of water through it.
Have no idea how hot the tractor runs because it doesn't have a temp gauge but I have used it regularly for 3 years now cultivating crops and it hasn't blown up yet so I can only presume that the cooling system is working.
I sure wish I had posted before buying the new rad. Trying to beat the time limitation to get a return on it. Thanks for the additional info.
2022 EZ-GO ELITE...
2 Row Cultivator (A64047)
2 Row Cultivator...
IH Farmall B Tractor (A66285)
IH Farmall B...
2015 Kenworth T680 (A64127)
2015 Kenworth T680...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A65643)
2008 FOREST RIVER...
